It is currently Sat Feb 28, 2015 1:07 pm
 Post subject: Need a replacement printer
PostPosted: Tue Sep 11, 2012 9:09 pm
Currently I own a HP Officejet 6310 All-in-One printer. This is my second HP printer to have basically crapped out. It takes forever to print and always gives cartridge errors.
I am looking to replace it with something reliable. Something that will work... I need to be able to print, scan and copy. Quality is my number one priority.
Looking at the Lexmark OfficeEdge Pro 4000. Does anyone have experience with this one or something better?
 Post subject: Re: Need a replacement printer
PostPosted: Wed Sep 12, 2012 9:53 am
Surprisingly, at least I was, Lexmark MFPs hold up very well. Even the smaller units like S315 and S415. At $70 and $80, both are real gems and do really sip their ink. And nothing beats the ability to scan, copy, print, fax and OCR over wireless n. You'll be hard pressed to beat the output quality, image refinement, onboard specs and price-to-performance.
http://www1.lexmark.com/US/en/catalog/p ... rodId=6604
http://www1.lexmark.com/US/en/catalog/p ... rodId=6603
PostPosted: Tue Mar 26, 2013 2:44 am
Loving my Lexmark OfficeEdge Pro 4000. Setup was easy and it works as intended! And I don't have to worry about wires!!! So glad I went with this.
PostPosted: Tue Mar 26, 2013 11:03 pm
Monkey Federation (Top 10)
I have also had good luck with Epson printers. They make commercial large format printers as well and use what they learn on the high end to make there personal printers better.
