It is currently Wed Apr 01, 2015 12:03 am
 Post subject: HD 6870 vs GTX 650 Ti
PostPosted: Tue Mar 26, 2013 9:58 am
I want to switch from my AMD card to NVidia (had some compatibility issues with 30" monitor and driver stability) and just heard that very affordable GTX 650 Ti came out. Performance wise would it be a step back from HD 6870 card?
Specifically I have this one and thinking of getting this one.
What do you think? :D
 Post subject: Re: HD 6870 vs GTX 650 Ti
PostPosted: Tue Mar 26, 2013 10:23 am
The GTX 650 Ti goes toe to toe with the 6870. If you can wait, the GTX 650 Ti Boost is coming out and will beat the 6870. And it starts at about $170.
PostPosted: Tue Mar 26, 2013 11:52 am
Thanks for the info! Yeah I can totally wait :)
