It is currently Sat Mar 28, 2015 3:52 pm
 Post subject: PC Display or
PostPosted: Sat Mar 09, 2013 2:03 pm
What works best HDMI or Display Port for a connection? It seams my text displays best with "Display Port".
Bob
 Post subject: Re: PC Display or
PostPosted: Sat Mar 09, 2013 2:19 pm
Neither. They're both digital signals trying to show the same thing.
PostPosted: Mon Mar 11, 2013 12:10 pm
HDMI is best for this. HDMI is intended as an external consumer electronics connection for HDTVs. It is rapidly replacing S-Video and component video as the primary connection to TV sets. HDMI appears on consumer monitors so that they can be connected to Blu-ray Disc players, game consoles, and other consumer electronics. This allows the monitor to be used as an entertainment display. HDMI is best found on PCs to enable connectivity to HDTVs.
PostPosted: Mon Mar 11, 2013 10:59 pm
Thanks to the bopth of you. Have have both monitors running. Know I'm trying to figure how to get the right monitor to act as my main monitor.
Bob
PostPosted: Tue Mar 12, 2013 5:38 am
Well, I just want to point out that HDMI video is the same as DVI. As for the display, copy and paste this into Explorer: Control Panel\All Control Panel Items\Display\Screen Resolution . Click on the display you want to be your main and there should be an option to make it your primary.
