It is currently Mon Apr 27, 2015 11:26 pm
 Post subject: How To Remove Dirt From The Corners Of An Led Screen?
PostPosted: Tue Feb 26, 2013 1:26 am
My 15" laptop LED screen has got dirt and sand particles in the corners around the sides, nothing can reach that place, and I can't use sharp or pointed objects to penetrate these narrow areas, is there any other trick I may use to remove these stubborn dirt particles, I'm afraid if I don't get rid of them immediately they may become permanent....
 Post subject: Re: How To Remove Dirt From The Corners Of An Led Screen?
PostPosted: Tue Feb 26, 2013 3:44 am
Million Club - 5 Plus
tried canned air?
PostPosted: Tue Feb 26, 2013 6:08 am
If you are avoiding a vacuum, an air compressor works wonders!
PostPosted: Wed Feb 27, 2013 6:34 am
you expect me to use an air compressor that size on a delicate 15" laptop LED? it looks like a mini power generator, lol
PostPosted: Wed Feb 27, 2013 8:05 am
Yeah, a can of air duster should do the trick. Or you can get a plastic spudger and gently pry it off.
PostPosted: Wed Feb 27, 2013 2:44 pm
Or you could just pop off the front bezel that goes around your screen to clean the entire surface
PostPosted: Sun Mar 03, 2013 12:24 am
Oh, it just pops off? You've done this? That's not how it works because they don't just pop off.
It's simple: a tissue can do this, Attention to detail. I'm not sure how dirty a corner can be, I think I've tested the lines of dirty screens, and none of mine are dirty.
Give it a puff dude. What's down in that corner anyway, dirty or not? Nothing happens in the corners of your screen.
