It is currently Wed Jan 28, 2015 1:17 am
 Post subject: Rip Music From Video
PostPosted: Sun Feb 24, 2013 12:33 pm
Need the ability to rip music from video. Basically they are music videos so I don't need to pick just a piece of the video that has music, it's the whole thing. Just want to rip it from the video into a music file, preferably MP3. Thanks.
 Post subject: Re: Rip Music From Video
PostPosted: Sun Feb 24, 2013 12:38 pm
I used to use SUPER, but I found out that Winamp Pro can convert formats it can play into audio files.
Otherwise take your pick from https://www.techsupportalert.com/best-f ... rogram.htm
PostPosted: Sun Feb 24, 2013 1:27 pm
XMedia Recode to the audiophile rescue. More powerful and portable than anything else on the planet.
PostPosted: Sun Feb 24, 2013 2:19 pm
Does XMEDIA have an American website I can use??? Don't speak German or whatever it is.
PostPosted: Sun Feb 24, 2013 2:26 pm
Just download and install it using English as the native language. If paranoid, use a US mirror.
PostPosted: Sun Feb 24, 2013 3:46 pm
Million Club - 5 Plus
Format Factory is another excellent option.
http://www.pcfreetime.com/
PostPosted: Sun Feb 24, 2013 7:52 pm
Read great things about Format Factory I will definitely try that, thanks!!!
PostPosted: Thu Apr 04, 2013 8:44 pm
I use a neat little program called Appgeeker.
I assuming you have some of mp4 files, check:
How to convert MP4 to MP3 audio on Mac and Windows
It will convert pretty much any type of file (video/audio/pictures/etc.) into pretty much any type of file. Really easy to use
PostPosted: Mon Nov 11, 2013 7:36 pm
You can use aneesoft video convert to rip music from video. All you need to do is converting your videos to .mp3 format.
