It is currently Sun Apr 19, 2015 3:15 pm
 Post subject: M11x 540M
PostPosted: Wed Jan 30, 2013 2:12 pm
Hi! I just got a M11x R3
Specs
i5 2537M
GT 540M 1024MB
4GB DDR3
500GB HDD
I was playing a game and decided to unplug it and then the FPS dropped drastically. I was guessing it was switching to the Intel HD 3000 but then I updated both my Nvidia and Intel Drivers and it still didn't help. So I used the Nvidia control panel and forced the GPU to the GT 540M and it helped the FPS alot but still not as good as it was before. So I pluged it back in and it the FPS went back up. Any ideas how to fix this? I would like Nvidia Optimus if possible so I can get full umph in games and maximum battery when not gaming. Thanks! :)
 Post subject: Re: M11x 540M
PostPosted: Wed Jan 30, 2013 3:57 pm
It's called "Oh crap, I'm on the battery, better start conserving energy!". If you really don't care about battery life while playing games, you have to do two things:
In NVIDIA control panel
  • Go to 3D Settings → Manage 3D settings. Make sure you're on the "Global" tab
  • Scroll down until you find "Power Management"
  • On the right column, click on it and select "Prefer Maximum Power"
In Windows
  • Go to Control Panel → Power Options → Click on "Change Plan Settings" on the power plan you want to configure this for → Click on "Change advanced power settings"
  • In the advanced power settings, click on "Change settings that are currently unavailable" (if it's there)
  • Scroll down to "PCI-Express", expand it to get to "Link State Power Management", expand that
  • In the settings, set it to "Off"
And it may just be a firmware feature, which is out of your control.
PostPosted: Thu Jan 31, 2013 12:21 am
Got the GPU issue fixed! But now I am dealing with Bluetooth... I have a Turtle Beach XP500 and I am trying to use it with my M11x and I couldn't get it to see the device (just needed a Driver) and now the issue is it says not connected. So I would appreciate some help with this as well! One other thing. I was just playing Metro 2033 at High, 1366x768, DX11 with no DOF, AAA. 4X AF with about 30-50FPS with a rare dip to 25FPS. Does anyone else have a similar PC and get these FPS at these Settings? Anyway need help with Bluetooth Headset. Thanks! :)
PostPosted: Thu Jan 31, 2013 12:39 pm
It connects to it but in audio properties it says not connected and seems to think it needs to be plugged into the audio jack.
PostPosted: Thu Jan 31, 2013 11:12 pm
I just got this PC about 3 days ago, and this afternoon while playing Red Faction Guerrilla my PC popped a notification in my face saying 7% battery remaining and I saw my PC was plugged in though. So I set the laptop down and noticed it was plugged into the wall, and cord was connected to the power brick but it had no light on. So I picked it up and it was really warm/hot so I put my PC in sleep mode and let the power brick cool down and then plugged it back in and it worked. But then it happened again... so I let it cool again. So my question is that will it be safe to use it until I get a replacement? I am planning on buying a 90W M11x power adapter off of EBAY tomorrow. Also my current one is 65W I think. So I should have it in a week. If it is not safe I would rather wait. I have a massive (and powerful) desktop to use in the meantime! I know this is not a video card subject but please help me I don't want to start a zillion different posts. Thanks! :)
BTW I tried multiple outlets.
