It is currently Fri Jan 30, 2015 11:16 am
 Post subject: First time builder needs help
PostPosted: Mon Jun 28, 2004 12:58 pm
Ok... i have an amd athlon 64 3400+ and i dont know how to put the thermal paste on. do i spread it over the whole topside? and then put the heatsink and fan that come with it on top of it?
PostPosted: Mon Jun 28, 2004 1:02 pm
o yeah... and i have 1 gig (512x2) of crucial ram. Can my athlon 64 use dual channal? Dual channel just means having 2 sticks in right? Do i have to just use 1 of them?
PostPosted: Mon Jun 28, 2004 1:46 pm
Team Member [Top 500]*
Just gently place a small (keyword is small) amount of paste on top of the processor. Just enough so when the heatsink and fan assembly are locked down in place it will distribute evenly. You dont want the thermal paste seeping or to ooze out and bleed on the edges of the processor or your mother board. It should form a thin layer between the processor and heat sink. If you happen to blow it and use excess, remove the heat sink and clean things with isopropanol alcohol and try again. Rest assured a single tube will do many processors as tiny as it is.
How much RAM and the RAM configuration is a function of your mother board, not the processor. Look at your motherboard specs to see the RAM configuration. Yes, dual Channel means a pair and to perform at its best the RAM should be a Matched Pair. Generally your motherboard manufacturers book will spell it out and suggest the RAM that is best suited for the chipset on the motherboard.
Hope that helps
Ron
PostPosted: Mon Jun 28, 2004 2:08 pm
1. open the slot for the CPU on the mobo
2. insert CPU
3. close slot (probably opens with a lever, well, close lever
4. spread a THIN layer over entire top of CPU (if i remember right, it has a heatspreader)
5. put on heatsink
PostPosted: Mon Jun 28, 2004 2:13 pm
There are some excelent instructions here: http://www.arcticsilver.com/arctic_silv ... ctions.htm
If your thermal paste isn't Arctic Silver (even though it really should be for best results) don't worry about it, the instrctions still apply.
PostPosted: Mon Jun 28, 2004 3:13 pm
Hi,
Am pretty sure that others who have responded to your question have already answered fully but the following URL might be of interest:
http://www.amd.com/us-en/assets/content ... 5-high.wmv
Best Regards.
Tailormadepc.co.uk
PostPosted: Mon Jun 28, 2004 4:19 pm
if the processor is socket 939 then it should support dual channnel,, but since amd doesnt currently offer 939 in 3400+ designation then nol
PostPosted: Mon Jun 28, 2004 6:16 pm
the mobo is an albatron k8x800 pro II. Do I just put a little on and then let the weight of the heatsink spread it or use the spread card that came with it?
PostPosted: Mon Jun 28, 2004 8:31 pm
Contributing Writer
Contributing Writer
Spread it yourself. Read over that link in a previous post pointing you to Arctic Silver's application instructions. You'll want a thin layer, and keep in mind that it may take a few days for your temps to fully adjust.
