It is currently Mon Mar 02, 2015 3:39 am
 Post subject: Movie File Won't Play on Xbox360 only when Streamed...??
PostPosted: Sun Dec 30, 2012 9:40 pm
Not sure really where to take this one but:
I have a movie file (just a tiny little 5 minute clip) in .mkv format.
my 360 will not play this file when I go into the media player and play it through my lan. (shared file on my PC) "can't play this content because it may not be supported...etc"
but if I simply copy the file to USB and plug that into the 360 then it will play that file...
what the...???
*same file*
 Post subject: Re: Movie File Won't Play on Xbox360 only when Streamed...??
PostPosted: Mon Dec 31, 2012 6:58 am
Team Dino
Team Dino
Are you simply sharing the file via SMB on your PC, or are you streaming it via DLNA?
n0b0dykn0ws
PostPosted: Mon Dec 31, 2012 7:12 am
Just sharing it via my WMP library.
PostPosted: Mon Dec 31, 2012 8:59 pm
Allo;
on the 360: My Video Apps -> System Video Player -> PC -> media file == does not play
on the 360: My Video Apps -> System Video Player -> Portable Device -> media file == plays just fine
(the "Portable Device" is simply a USB stick)
so it's the same player on the 360, same file, but two different "locations". Should play them both it seems... no?
PostPosted: Mon Dec 31, 2012 9:57 pm
Depends on what the computer is doing. I can't access my music files on my desktop from my PS3 sometimes.
PostPosted: Mon Dec 31, 2012 10:00 pm
Computer was idle - not sleeping and not hibernating just idle
