It is currently Tue May 05, 2015 1:35 am
 Post subject: Can I use two different video cards on same PC ?
PostPosted: Tue Nov 13, 2012 2:32 am
I have a Dell T – 7500 workstation which came with AMD FirePro 2260 Video Card.
I removed it & installed AMD FirePro 2460 Video card to run a total of 4 Monitors ( This Video Card has 4 Mini DP Port & comes with 4 Mini DP To DVI Converter Cables )
All monitors are identical.
Now one of those 4 Mini DP To DVI converter cable has failed & I am left with only three functioning monitors.
( I tested everything & narrowed it down to the converter to be the culprit )
I am thinking about plugging back the original FirePro 2260 video card which will run the 4th monitor till I get the replacement converter.
So my question is if those two different Video Cards will work together ? ( Yes, FirePro 2260 has DP to DVI Converter )
If yes, do I need to download two different drivers ?
From AMD’s site, it seems both use same drivers.
http://support.amd.com/us/Pages/AMDSupportHub.aspx
http://support.amd.com/us/gpudownload/f ... n7-64.aspx
Many Thanks
 Post subject: Re: Can I use two different video cards on same PC ?
PostPosted: Tue Nov 13, 2012 8:17 am
From what I know from other people, yes you can mix and match and yes you will need two different drivers if they're not the same GPU.
