It is currently Sun Feb 01, 2015 6:10 pm
 Post subject: Fast and quiet upgrade
PostPosted: Sat Nov 10, 2012 7:21 pm
Hi all, I want to upgrade my Nvidia 460ti to the fastest but quiet video card available. I play video games as well as mid level video editing so I want to stay with Nvidia because of Cuda, so if anyone has any expert advice on a recommendation I would appreciate any help.
TIA
 Post subject: Re: Fast and quiet upgrade
PostPosted: Sat Nov 10, 2012 8:45 pm
Define quiet, because I have a GTX 560 Ti stock and when it's blasting I don't notice a thing (although having a grill over the expansion slots might have something to do with it).
If I were to guess, something like this three slot beast should be quiet enough. Otherwise you'd have to buy some aftermarket cooling system.
PostPosted: Mon Nov 12, 2012 3:20 am
Quiet to me is barely audible at full load. I will be upgrading my case to a more quiet case also because I want to build a silent PC for my office. That card is a beast, what brand is your 560.
Thanks for the response.
PostPosted: Mon Nov 12, 2012 7:55 am
I guess I broke my own rule. I barely notice my setup because the air has to go through a grill and my desk and it has to beat my speakers. And if there's nothing playing on my computer, then that's the only time I can hear it.
The brand is EVGA, but the 560 Ti uses the reference cooler, which is something you shouldn't use if you're looking for quiet.
PostPosted: Mon Nov 12, 2012 10:35 am
Gigabyte is pretty much your destination for fast AND quiet: GIGABYTE GV-N66TOC-2GD GeForce GTX 660 Ti 2GB That's the same card Anandtech benched when the 660ti's first came out. At that time it was the best overclocker & quietest under load. Of course now there are triple fan options that drop noise a little more. If I were in the market for a new GPU right now, that's the one I'd get, & I also do a lot of gaming (1920x1200) & 1080p video editing.
PostPosted: Mon Nov 12, 2012 10:51 am
Thanks for the great advice I will have to compare each card and see which one works out. It seems cards are quieter now which is defiantly a good thing for me.
Thanks again!
