It is currently Mon Jan 26, 2015 7:48 am
 Post subject: Please suggest best PC benchmarking software...
PostPosted: Mon Oct 29, 2012 2:25 pm
Hi Guys.
Can you please suggest a good, preferably free, benchmarking software for a new custom PC?
Thank you! :!:
 Post subject: Re: Please suggest best PC benchmarking software...
PostPosted: Mon Oct 29, 2012 3:45 pm
All depends. What do you want to measure? CPU? GPU? Memory? HDD? SSD? Boot times?
I bet all of the above, so the easiest place to start is here even though some of the tools have been updated and their are better options like 3Dmark, PCmark, Furmark, Afterburner, SiSoftware sandra, x264, Cinebench, Memtest, CrystalDiskMark, nnn. But first off, what is your WEI?
PostPosted: Wed Oct 31, 2012 1:29 pm
Thank you for your reply.
Because of a chassis issue, I haven't been able to assemble the parts. It's quite a high end build-- the parts totalled $4000.
I will be utilizing your suggested software.
Thank you!!! :D
-Matt
PostPosted: Wed Oct 31, 2012 2:09 pm
$4 Large! Are your serious? I just shit myself....
Be a gem and help the clean-up by sharing your part spec that makes up this Godzilla build.
PostPosted: Wed Oct 31, 2012 6:24 pm
Hiya.
I hit the jackpot with a situation that gives me 66% off, so I went very large. (don't ask me why I need 32G of 1866 ram, except that i plan to create a RAM drive. lol!)...
ClearPC® MIDTOWER Classic
- Add Side Panel Portholes 10, 1in. Holes, 5 Top and 5 Bottom Edge of Side Panel
- Fan Modifications, Back 1 x 120mm
- Fan Modifications, Front 1 x 120mm
- Fan Modifications, Side Panel 1 x 120mm
- Fan Modifications, Top 1 x 120mm, Center
Quantity= 1
OCZ ZX Series 1000W Fully-Modular 80PLUS Gold High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
Newegg Item #:N82E16817341045
Quantity= 1
CyberPower CP1350AVRLCD 1350 VA 810 Watts UPS
Item #: N82E16842102070
Quantity= 1
ASUS Xonar Essence STX 124 dB SNR / Headphone AMP Card
Newegg Item #:N82E16829132010
Quantity= 1
SAMSUNG CD/DVD Burner Black SATA Model SH-222AB
Newegg Item #:N82E16827151233
Quantity= 2
CORSAIR H70 Core High Performance Liquid CPU Cooler
Newegg Item #:N82E16835181019
Quantity= 1
ASUS Rampage IV Formula ATX Intel Motherboard
Newegg Item #:N82E16813131808
Quantity= 1
Corsair Force Series 3 CSSD-F240GB3A-BK 2.5" Internal Solid State Drive (SSD)
Newegg Item #:N82E16820233268
Quantity= 2
Intel Core i7-3930K 3.2GHz (3.8GHz Turbo) LGA 2011 Six-Core Desktop Processor
Newegg Item #:N82E16819116492
Quantity= 1
CORSAIR Vengeance 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory
Newegg Item #:N82E16820233237
Quantity= 1
GIGABYTE GeForce GTX 680 GV-N680OC-3GD Video Card
Quantity= 1
Antec 761345-75024-0 Blue LED Case Fan
Newegg Item #:N82E16835209011
Quantity= 5
AeroCool X-Vision 5.25" Bay control 5 sets of Fans and Temp and voltage display. Color LCD Monitor
Newegg Item #:N82E16811999230
Quantity= 1
PostPosted: Thu Nov 01, 2012 9:15 am
Million Club - 20 Plus
I plug all that you have listed in at newegg and come up with a total cost of $2859 not $4000.
(Of course shipping wasn't included. Nor did I use any MIR's to reduce prices. )
Just a personal observation here, two CD/DVD burners? Personally I would buy one CD/DVD burner and then add a BluRay Burner. (Which is exactly what I do have in mine.)
PostPosted: Thu Nov 01, 2012 12:16 pm
Add case = $180
check quantities of each item.
uninterruptable power supply = $150
Tax + shipping.
= $4000
PostPosted: Thu Nov 01, 2012 2:24 pm
$4 Large is a bit silly. Carve off $1K and build this instead, then send me the difference. A small box of $50's is preferred.
$170 - 3570k
$60 - AsRock Pro4 with $50 MicroCenter bundle discount
$34 - 8GB Samsung MV-3V4G3D
$290 - Gigabyte GTX 660Ti OC
$120 - Barracuda 3TB
$130 - Agility 4 256GB
$90 - Seasonic X650
$15 - Samsung 22x DVD Burner Model SH-222
$70 - Fractal Arc Midi
$979
