It is currently Mon Apr 27, 2015 6:09 pm
 Post subject: Dual Monitor Setup
PostPosted: Wed Oct 03, 2012 3:19 pm
I want to set up a 2nd monitor in order to have a dual monitor setup. I currently have an ATI Radeon HD 4850 video card. Based on this card and a two monitor setup, would I have any issues playing games such as CoD, Diablo3, etc? Perhaps not at max settings but is there another way or something I should do in order to get a better setup going?
Thanks in advance.
 Post subject: Re: Dual Monitor Setup
PostPosted: Wed Oct 03, 2012 3:26 pm
No, the only caveat is that the other monitor may blank out in full screen games. So if you want to monitor something, you'll have to run in windowed mode.
PostPosted: Wed Oct 03, 2012 5:07 pm
In terms of gaming performance, will it suffer because it has to send a signal to two monitors?
PostPosted: Wed Oct 03, 2012 6:20 pm
Partly, as the video card doesn't cut the signal off to the second monitor. So you use some VRAM for the framebuffer (although it may be able to store that in RAM)
