It is currently Tue May 21, 2013 9:52 pm
 Post subject: Post your AS SSD Scores
PostPosted: Fri Sep 28, 2012 6:55 am
 Post subject: Re: Post your AS SSD Scores
PostPosted: Fri Sep 28, 2012 9:32 am
Mushkin Chronos 120GB SSD in RAID-0
OCZ Vertex 4 128GB SSD single drive
PostPosted: Thu Oct 11, 2012 3:13 pm
One more to add... this is on the new motherboard Intel SATA 3 controller, 2x Vertex 4 128GB SATA III SSD's in RAID-0. Prepped them for the new board by re-flashing 1.5 firmware (shipped with 1.5 but why not...), and performing secure erase on both SSD's.
HOLY $HIT that's impressive considering the AMD controller would hit 1.1GB/sec in ATTO, but the Intel controller can just barely hit 900MB/sec in ATTO with default settings in both cases... Not to mention more than double the score of a single drive on the AMD controller :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
PostPosted: Tue Oct 16, 2012 9:57 am
I'm stunned, shocked and blown away with these results!! This is on your new Extreme9, right?
PostPosted: Tue Oct 16, 2012 11:15 am
That makes two of us :!: and yes, it's on the X79-Extreme9.
I'll check it out again in 2 weeks after my burn-in is completed, base-line testing is done, all my games & programs are installed, & the array has a little bit of use on it.
PostPosted: Sat Oct 20, 2012 5:12 am
Are you seeing any real world benefits of your new Vertex4 array bench speeds?
PostPosted: Mon Oct 22, 2012 2:19 pm
Actually... nothing "noticeable" outside of benchmarks. Boots into windows 2 seconds faster than a single Vertex 4. Programs seem to open just as fast, game levels seem to open just as fast... If I sat there with a stop-watch & timed everything, I could probably find some improvements, but the 'feel' of the PC is about the same Vs a single Vertex 4.
PostPosted: Sun Oct 28, 2012 8:20 am
Okay, here we go, 3 weeks of use, burn-in complete, base-line testing complete, got tons of games & programs loaded on this puppy, 144.2GB worth of programs & games, all my data is of course moved to/stored on the HDD's.
Considering that the array is now over half full & was only 4% full when the first test was run, I would say that's not bad at all!!!
