It is currently Sat Jan 31, 2015 7:35 am
 Post subject: vga to dvi?
PostPosted: Thu Aug 30, 2012 1:09 pm
I thought about it and I honestly have no idea if it would work. But would it be possible to use a DVI to VGA adapter the other way around? So the signal comes from the vga side not the dvi side.
 Post subject: Re: vga to dvi?
PostPosted: Thu Aug 30, 2012 2:34 pm
If you mean VGA out, DVI in, then no. The input's expecting DVI.
PostPosted: Thu Aug 30, 2012 4:30 pm
So it will only accept signals coming from the DVI side of the adapter then and will only output on the VGA side correct?
PostPosted: Thu Aug 30, 2012 4:39 pm
Yes.
If you want a technical explanation, the only pins that actually interface with the DVI plug are the DVI-A pins (http://en.wikipedia.org/wiki/File:DVI_Connector_Types.svg, pinout http://en.wikipedia.org/wiki/File:DVI_pinout.svg).
