It is currently Sun May 03, 2015 5:10 am
 Post subject: graphics card help
PostPosted: Wed Aug 15, 2012 9:19 am
3rd attempt lucky lol
hi my names rob new to the forum so be gentle lol
i have a hp pavallion 640gb hdd 4gb ram quad core amd phenom with a ati hd4350 card and its not good enough for the games i want to play, can soneone recommend me a reasonably priced card any compatible make and preferably a link to a trusted site for purchase? Thanks in advance
oh to play games like skyrim and wow
 Post subject: Re: graphics card help
PostPosted: Mon Aug 27, 2012 6:23 am
You have to make sure your PSU has a plug to power a GPU and that the psu has enough power as well.
The 4350 doesn't use much power at all, so any competent GPU will be additional drain.
http://forums.atomicmpc.com.au/index.php?showtopic=264
That said, consider a Radeon 7750 or 7770. Both quite efficient and should give less power problems.
http://www.newegg.com/Product/Product.a ... 6814127687
It's not a really powerful card, but it will get the job done, and given your OEM system status, it's probably a safe pick.
