FascistNation wrote:
I suspect the first CPUs won't support it unless AMD comes out with it built in (as it did with native SATA III and native USB3 support forcing Intel's hand, just an Intel forced AMD's with built in graphics).
Intel didn't force AMD into built in graphics, AMD had been working on an APU since around 2008, and had their first working protoypes in 2009. Of course they didn't go to market till after Intel, & some people think that was on purpose in order to see what Intel would be bringing to the table. Of course, AMD's integrated graphics solution is vastly superior
if you ignore the CPU performance side of the APU equation & that's not even looking at the upcomming A10 APU's...
Just as AMD has not forced Intel into SATA III or USB3.0 support... AMD has supported 6 onboard SATA III ports since their 800 series chipsets (when coupled with the 850 south bridge) z68 launched in May 2011 with native SATA III support for 2 ports. Was this in response to the 800 series chipsets from AMD??? I think not, but advantage AMD due to full SATA III support on all ports... yet a year later when Intel launched z77, still only 2 SATA III ports supported by chipset... kind of makes you think that Intel doesn't give a shit about what AMD is doing...
Native USB 3.0: AMD has only had it since FM1 platform was launched last November. That's right the 900 series chipset boards with USB3.0 all use a third-party chipset for USB 3.0 support. Gigabyte & ASRock uses an Etron chipset, ASUS uses an ASMedia chipset, MSI uses a NEC chipset etc... So in actuallity,
AMD still does not have a mainstream board with native support for USB 3.0 and won't till 2013... & before you say yea, but... FM1 is a niche board that was already EOL when it was launched. FM2 will launch shortly, but its still a niche platform, and destined for a quick EOL as well.
AMD is going to have to triple their current performance while reducing power requirements if anything they do is going to have any affect on Intel. Right now Trinity is the best thing going for AMD, and it's not even out yet. But I'd rather pay more and go with LGA2011 than save money & go with Trinity because I do
High Definition video editing & encoding, where 12 threads are fully utilized, & I already have 4 DDR3 DIMMS for quad-chanel support. "yea, but you should be looking at the upcomming Piledriver based FX-8350, not Trinity for video encoding"... yea, but who knows when those will actually be available, and the power requirements are still outrageous... Performance per $ & Performance per Watt will still go to Trinity, not the FX chips.... AMD is on the right path with Trinity, I just hope the new CPU architect AMD hired can latch on & improve it, then we might have some real competition going again & then Intel might start taking notice...
