It is currently Sun Jan 25, 2015 11:25 am
 Post subject: Radeon HD 7850 vs Hd 5750
PostPosted: Tue Jun 05, 2012 4:55 pm
I currently have a Sapphire Vapor-X Radeopn HD 5750 1GB 128-bit GDDR5 PCI Express 2.1 video card. I'm looking to upgrade to a Sapphire Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 video card. Does anyone know how they compare in terms of heat and noise level?
 Post subject: Re: Radeon HD 7850 vs Hd 5750
PostPosted: Tue Jun 05, 2012 5:17 pm
If http://www.anandtech.com/show/2856/13 and http://www.anandtech.com/show/5625/amd- ... islands/17 are anything to go by ( they use a reference design, I believe), better. But considering it's from a video card manufacturer that probably did a custom job, probably the same.
PostPosted: Sat Aug 18, 2012 4:56 am
Anyone have any direct experience with these two cards?
PostPosted: Sat Aug 18, 2012 9:36 am
At this point you should just use that search engine they call Google.
PostPosted: Sat Aug 18, 2012 10:17 am
Already tried that. Found a number of people with one or the other - no one with direct experience with both.
PostPosted: Sat Aug 18, 2012 12:40 pm
Okay, so you take what you found and make a comparison on that. You'll probably have a better chance being struck by lightning twice than finding someone who has both.
PostPosted: Sat Aug 18, 2012 5:15 pm
There's plenty of things you can do about the heat and if it is really that loud, which I doubt, move your PC a little further away from you.
I did cause my mobo had the PS2 autostart option meaning if I just touch my mouse my PC powers up so my PC has no need to be near me.
