It is currently Tue Jan 27, 2015 5:30 pm
 Post subject: Upgradeing card?
PostPosted: Sat Apr 21, 2012 2:26 am
Ok this is my first post here so go easy....I have an asus A8N32-SLI DELUXE Motherboard running win 7 64, 4 gigs of ram, I was running 2 7600 gt bfi cards and wanted to upgrade to a single 6670 card,. the question I have is the 6670 is a pcie 2.1 will it run in this motherboard ? The card requires a 400 watt power supply I have a diabloteck 680 so i should be good there.
 Post subject: Re: Upgradeing card?
PostPosted: Wed May 30, 2012 3:04 am
What cpu do you have....if I were you I would be wondering if the CPU is going to create a bottleneck and the new video card will be loafing while waiting for the wire-fames to be worked on that are coming from the CPU. You may be better off saving your money for a new build.
PostPosted: Wed May 30, 2012 7:03 am
That's a Socket 939 board, an 8800GT was bottlenecked by it.
So it's time for a new computer.
