It is currently Thu May 23, 2013 1:18 am
 Post subject: This device cannot start (code 10)
PostPosted: Mon Aug 01, 2011 6:50 pm
Hello all, I've just put together a new system and have everything up and running just dandy. However, my LAN port is giving me a bit of trouble as I get the error code, this device cannot start (code 10) from device manager.
The motherboard I am using is the Asus P8Z68-V Pro. I have downloaded the latest drivers from Intel for the Gigabit Ethernet Controller and that has not solved the problem. I've every which way of installing the drivers and none of them worked. I even ran CCleaner's registry cleaner to see if that cleared anything up but no luck there either. The other thought I had was to update Windows but since I have no network connectivity that will not likely happen. The exact port on the board is the Intel 82579LM.
My question to you is, have you come across this error code before and if so how have you solved it? Also if you need any more info from me I'll be glad to provide it.
Thanks.
 Post subject: Re: This device cannot start (code 10)
PostPosted: Mon Aug 01, 2011 7:25 pm
Right-click on the network adapter in the Device Manager and select "Uninstall", then reboot the system. This should solve your issue.
PostPosted: Mon Aug 01, 2011 7:37 pm
Thank you for the reply, but I have already tried that one out and no luck, I get the same error code.
PostPosted: Sat Aug 06, 2011 6:32 am
Is the port turned on in the bios?
PostPosted: Sat Aug 06, 2011 11:54 am
Yes, the port was turned on in the BIOS. After numerous tests I finally determined it was bad hardware and nothing could be done except for an RMA Return. Ended up getting a Gigabyte GA-Z68XP-UD3P and everything works flawlessly.
PostPosted: Sat Aug 06, 2011 12:04 pm
Sometimes drastic measures are needed. :D
Users browsing this forum: Google [Bot] and 1 guest
