It is currently Sat May 18, 2013 9:45 pm
 Post subject: AMD Athlon 64 4000+ and K9AGM2 mobo, worth messing with?
PostPosted: Fri Nov 12, 2010 9:46 am
A friend of mine just gave me this motherboard and CPU that have never even been opened. He won them at a tech conference.
I know nothing of AMD products but since it was free I did not refuse.
I know these two items are a few years old is it worth it to put a cheap system together around them? Talking about spending maybe $100 or 200 (already have an 8800 gt OC to throw in) and getting either a game server, media server or nas going.
Edit/Delete Message
 Post subject: Re: AMD Athlon 64 4000+ and K9AGM2 mobo, worth messing with?
PostPosted: Fri Nov 12, 2010 10:39 pm
for what you are talking about using it for, it will do quite nicely.
PostPosted: Sun Nov 14, 2010 12:10 pm
You can slap some memory and any old HDD in there and give either WHS evaluation or WHS2 (Vail) Beta a try just to show that it's more than enough for media/NAS/backup/server uses. WHS is really nice to have for home and work, and WHS2 seems to be a good update. The beta is limited in what it's capable of doing thus far, but it's just a test. It should run around $100 once final, but you can't upgrade from BETA to Final Release meaning the server will start over from scratch.
Just as a reference, I used a Pentium4 651/2GB DDR2 667/2x 500G HDD's and it worked fine. It's now updated (E4600/2G DDR2 800/4 1TB HDD's) just because the parts were around and feel the HDD updated it more than anything. A Q6600 didn't help it one bit, so it got pulled for better uses. The CPU just isn't taxed so you can underclock/undervolt it pretty far to keep it really cool and quiet, and perhaps stash it in a nook where it's out of sight. FWIW, I'm trying out the BETA with an IDE 120G drive on better hardware than the main WHS and it's fairly slow to transfer or begin reading media.
Not sure about a game server. It'll work for internal LAN's, but could be hindered by your ISP's upload speed if you want an externally pointed game server. There, memory helps too.
