It is currently Sun Jan 25, 2015 12:33 pm
 Post subject: crossfire hd 5770
PostPosted: Thu Feb 25, 2010 7:27 pm
I have a Diamond HD5770 video card in my rig now that I'm using. Can I add another HD 5770 from another supplier like xfs and run it in crossfire mode?
From what I understand all ati HD 5770 cards use the same chipset.Would there be any driver issues pairing up two different HD 5770 cards from different manufactures?
PostPosted: Thu Feb 25, 2010 8:00 pm
Million Club [PC]
Million Club [PC]
you can. Any 5770 will CrossFire fine with any 5770. clock speeds and amount of memory doesn't matter, though if you CrossFire a 1GB card witha 512MB card, you lose half the frame buffer on the 1GB card.
PostPosted: Fri Feb 26, 2010 4:55 am
thanks for the reply. I found another card used for a under a $100 dollars and wanted to make sure that it would be compatible for crossfire configuration.
