It is currently Fri Aug 01, 2014 4:13 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
How many fans you got ?
1 - 3 16%  16%  [ 9 ]
4 - 7 63%  63%  [ 35 ]
8 - 11 9%  9%  [ 5 ]
11 + 7%  7%  [ 4 ]
I hve a separate power supply for all my fans. 5%  5%  [ 3 ]
Total votes : 56
PostPosted: Wed Dec 29, 2004 8:54 pm
M-Powered
M-Powered
Your poll sucks, there's no "0 fans" option. :roll: :wink:
PostPosted: Wed Dec 29, 2004 9:02 pm
Ha, Only have 2 fans, 1 on my PSU, 1 on my proccessor. My heat dissapitation sucks :o
PostPosted: Wed Dec 29, 2004 11:29 pm
Well, I have:
1 x 90mm CPU
2 x 80mm Exhaust
1 x 80mm side intake
1 x 80, 1 x 90 PSU
1 x GPU
Total: 7
PostPosted: Thu Dec 30, 2004 9:21 am
Well i have an old 850MHz pentium 3, but i have upgraded and added alot of modern equipment into the pc, but anyway i have 1 fan in the PSU and the other fan which is the main one is the one sitting over the processor which takes all the air out. It has like a big tube the fan sits in over the processor and takes all the air out. So yes i only have them 2 fans. Also if you want to add the one on the graphics card that would make 3.
PostPosted: Thu Dec 30, 2004 3:57 pm
Everyone should list what case they have and temps so other can get an idea of how to improve their cooling :)
PostPosted: Thu Dec 30, 2004 7:27 pm
M-Powered
M-Powered
Case: LianLi IP-40
No. of fans: 0
CPU Temp: -58C
Case Temp: 31C
Doubt anyone will find that useful.
:wink:
PostPosted: Thu Dec 30, 2004 7:49 pm
Team Member Top 100
Team Member Top 100
1 - 120mm rear
1 - 120mm front
1 - 120mm side
1 - 92mm cpu (Zalman CNPS-7000 AlCu)
2 - ~40mm gpu
2 - psu
______________
8 - Total
My 2.8c@3.5 runs around 42/27C with 1 F@H client running in the background.
PostPosted: Thu Dec 30, 2004 8:01 pm
I think I have two in my laptop, one intake and one outlet. But I have a Vantec lapcool 2 that has two more fans. So total I have 4 for a lapper. :lol: She gets pretty hot.
PostPosted: Thu Dec 30, 2004 9:10 pm
Team Member Top 50*
Team Member Top 50*
Location: Folding in Ontario, Canada ------------------------- Team Rank: 44
2x80mm intake
1x80mm exhaust
1x80mm CPU
1x60mm videocard
2x80mm PSU
___________
7 Total
PostPosted: Fri Dec 31, 2004 7:51 am
I have 9. Two rear for exhaust, two intake and one blowhole. If you count the GPU fan, the dual psu fans, and the cpu hsf then I have 9 fans total.
BTW I reccomend ThermalTake 80mm fans...
PostPosted: Fri Dec 31, 2004 12:46 pm
1 90 mm in PSU
1 stock on GPU
2x 90 mm blowing on both cpus.
2x 90 mm blowing air out
1x 90 mm blowing air off both cpus (windtunnel design)
2x 90 mm blowing air in front blowing cool air onto hdds and bringing air into windtunnel
1x 40 mm fan (high flow) blowing air on memory
All 90 mm are powered by a 140 watt mini atx psu with another 90 mm fan on it.
Overall, my computer isnt too loud still.
PostPosted: Fri Dec 31, 2004 12:49 pm
maxx wrote:
Case: LianLi IP-40
No. of fans: 0
CPU Temp: -58C
Case Temp: 31C
:wink:
are you using a phase change cooler, or you using a water system that is cooled with a phase changer?
PostPosted: Fri Dec 31, 2004 1:32 pm
M-Powered
M-Powered
Dual stage condenser for the CPU.
Two water cooled loops with a huge passive radiator for everything else (GPU, North Bridge, Hard Drives and PSU).
Both the condenser and radiator are (permanently)borrowed from our labs, designed to cool mission critical microwave telecommunications equipment, so they're much more sophisticated then your average Vapochill...
PostPosted: Fri Dec 31, 2004 11:23 pm
2 - PSU exit
1 - CPU
1 - MOBO
1 - 120mm side intake w/ dust filter
1 - 80mm front intake
1 - 80 mmrear exit
1 - 6800 Ultra OC
1 - PCI slot mounted exit fan next to vidio card
6 - 2 small fans mounted on each of my hard drives
1 - In my removable 5 1/4 HDD bay
16 total, I win. Surprisingly quiet too. NOW MY PC MOVES ENOUGH AIR MY WIFE CONCIDERS IT A HEATER, MY OFFICE GETS HOT!!! Yet another use for my obsession :twisted: mwwhhHAAA HA HA HAAaaa! :twisted:
PostPosted: Sat Jan 01, 2005 1:29 am
[unclan] Rhino wrote:
2 - PSU exit
1 - CPU
1 - MOBO
1 - 80 mmrear exit
1 - 6800 Ultra OC
you do know that those small 40 mm fans are useless when cooling your hdd unless your using the thick 40 mm fans for servers. Anyways, use a 80 or 90 or 120 mm fan to cool them, it probably will be quieter.
PostPosted: Sat Jan 01, 2005 1:30 am
I c, pics of your setup? With your talk of opterons and dual cpus, i would of thought you used a dual cpu setup
PostPosted: Sat Jan 01, 2005 3:01 am
I have 2 fans total, one on my power supply, and one on the processor. I have an open grill thing that I can add another fan into if I want (my case was cheap and didn't come with any fans), but at the moment I'm broke.
Even with just two fans, I think my case is still kind of noisy, but I'm not going to complain. As long as I hear some kind of faint humming when I push the power button, I'm happy.
PostPosted: Sat Jan 01, 2005 4:25 am
Hasn't having huge quantities of fans being "cool" go out of style yet?
Two 120's, hardly ever on. One 80mm on the top that has never been plugged in. It's about to get teh yank.
PostPosted: Sat Jan 01, 2005 6:39 am
Chief Surgeon
Chief Surgeon
1 on CPU
1 on GPU
1 on Chipset
2 80mm on Case Front
1 80mm on Case Side
1 120mm on Case Rear
I voted 7, but now realize I have two fans in my PSU.
