It is currently Fri Jul 25, 2014 8:14 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Where's My Thread? -> HH Bylaws
PostPosted: Sun Nov 28, 2004 12:21 pm
There is no cause for alarm... yet
This forum is for circuit-level conversations on all that's going on with gear.
Multimedia (monitors, projectors, DVD/CD) , Internet/Communication, Mobile devices (laptops, PDAs, etc) and Overclocking hardware should be discussed in the Multimedia Madhouse, Network Nook, Roadwarrior Pitstop and Overclocker's Corner respectively.
If you need help - use the Free Clinic and remember to check its posting tips so we can help you better.
Threads that do not match forum criteria will be moved. We Moderators try to PM upon moving threads, but don't always have time.
Please be aware that multiple threads of the same topic in the same forum or across forums is considered spamming - pick one. We appreciate that some topics cross over, but numerous threads of the same subject makes it difficult to coordinate help if you're trying to keep track of 2+ threads.
If unsure who is a Moderator - refer to The List.
Not all Mods are on at the same time - quickest way to get a response is to post in the Forum & Website Feedback forum.
PostPosted: Fri Sep 30, 2005 3:59 pm
In the lab!
In the lab!
Oldie but a goodie!
