It is currently Wed Jun 19, 2013 9:21 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3  Next
 Post subject: How to mOd a Test PSU
PostPosted: Sun Sep 26, 2004 10:11 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Making a test psu is a very easy mod. It is very usefull if you build computers and need to test components without a mobo. The following are easy steps to follow to get your test psu up and running.
Above are the materials needed for this project- a wire cutter, a wire stripper (I use needle nose pliers), a working psu (AT or ATX), and electrical tape or heat shrink tubing.
First, out of all the connectors in the ATX bundle find the biggest one. This is the one that connects to the mobo. Because I was using an older AT psu there are 2 of these connectors, but if you are using a newer psu there will probebly be one larger one.
In the bundle of wires coming from the large ATX connector and find the green wire. Directly to the left of the green wire will be a black wire. These are the wires you will be cliping. Again since I was using an older AT psu the green wire was orange.
Go ahead and clip the green and black wires as close to the connector as you can, strip the ends of these wires and twist them together. Then close it up with some electrical tape or heat shrink tubing.
Congrats your test psu is finished. Now hook a cd rom up to it or another component and fire it up.
gamerfreak
PostPosted: Sun Sep 26, 2004 10:14 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Thanks manta for translating it into bb code.
And BTW manta when I seperated the orange and black wires the unit would'nt power up. Thanks anyway though.
PostPosted: Sun Sep 26, 2004 11:03 am
I'd rather be modding!
And BTW manta when I seperated the orange and black wires the unit would power up. Thnaks anyway though.
It would or it would not?
Doesn't really matter - for an ATX you have to cut them. Good how to. I will post it in the MRL when I get a chance.
I like that it is to the point - the other How-to (in the MRL) spends a lot of time making it look pretty and thus making it more complicated than it really is (and more dangerous).
You didn't mention it, but using this technique is how you would get two PSU's into one case. Something a modder might like :)
Manta
PostPosted: Sun Sep 26, 2004 2:58 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Would not, sorry one of my many typos.
PostPosted: Sun Sep 26, 2004 3:14 pm
Celeron
Celeron
Nice Tutorial.
One question: How do you exactly hook it up? Plug in the PSU and plug a cd drive to a molex connector?
PostPosted: Sun Sep 26, 2004 3:17 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Yeah, use it like you would a regular PSU, the only thing different is that it doesn’t require a connection with the motherboard it function properly. Just don’t use it in a computer if you make one. After you snip those wires t is for test purposes only.
PostPosted: Sun Sep 26, 2004 3:20 pm
Celeron
Celeron
Alright, Got it! Thx for the info. Im gonna try this in the future.
PostPosted: Sun Sep 26, 2004 3:27 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Great :D Good luck :wink:
PostPosted: Sun Sep 26, 2004 4:52 pm
The point is, it can power anything without being hooked to the MB. You can use it as a test PSU like Gamers says - or, if you are a modder - it makes a great secondary PSU for drives and other power hogs.
Imagine building an 1100 watt computer :>
Manta
Kewl - thats what I thought :)
Manta
PostPosted: Mon Sep 27, 2004 7:15 am
darn, i just tossed an old 150 in the garbage. I could use a test PSU... maybe I'll dig it out...
that is a good tutorial, cept the pics didnt show for me. not sure why...
but i understand how to do it. (just splice the black and green wires together right?)
PostPosted: Mon Sep 27, 2004 1:57 pm
Gamer was supposed to put the pics in his photobucket account after I optimized them. Instead he linked to my account - which would be fine, but I think I am at the end of my bandwidth. Maybe he will move them back over soon. You should be able to see them now.
If its an ATX PSU with one MB connector, then I think you bridge the green and black ones. If its an older AT PSU with 2 MB connectors then you have to do the orange wire
There is a harder to follow PSU mod in the MRL.
Manta
PostPosted: Mon Sep 27, 2004 3:28 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
ohh sorry manta il will do it now
PostPosted: Mon Sep 27, 2004 3:36 pm
Why go through the cutting process though? Why not take a short piece of wire and jumper the two pins?
PostPosted: Mon Sep 27, 2004 3:38 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
that is another way to do it
PostPosted: Mon Sep 27, 2004 3:49 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
They are coming from my account now manta. Sorry about that. I have a bad history of acidently leaching bandwidth.
PostPosted: Mon Sep 27, 2004 5:26 pm
That would work - and a switch would work too (even better).
Yet, the history of this was that Gamer wanted a simple way to make a test PSU that didn't involve opening the PSU case and would be permanent.
Its funny ya know, this is simple - yet when you look online all the how too's are complex :).
Why do you think that is? Very distracting from what you are really doing - makeing a stand alone PSU.
I know I thought about just jumping the wires at the connector - but for me - something more permanent is required. I don't know what Gamer wants to do with one, but this was a commport discussion about two PSU's in parallel for a mod at one point and simply shorting at the connector was not enough (is has to be a bit more secure than that). OTOH, removing them from the bulkhead is too dangerous for the newbie modder (and even some of us careless advanced ones :) )
If I did it I would use a switch - but then we would get another way too complicated "how to" for something like this.
Seriously, google it and ask yourself what you would think if you didn't know a good bit about electronics. Such a simple thing looks all complicated and stuff.
Anyways, avioding work again TTYL
BTW - thanks Gamer - I have the super free photobucket account - its not stable :) Do you pay them or something? Yours is better than mine - you have a security wall. Whats up with that?
Manta
PostPosted: Tue Sep 28, 2004 3:03 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Hmm i dont pay them. I just use the free account. lol. Maybe they like me better. :wink:
PostPosted: Tue Sep 28, 2004 5:01 am
They must - yours is secured, mine is not.
I will have to look into that.
I have a very old acocunt - maybe thats the deal.
Manta
PostPosted: Tue Sep 28, 2004 11:31 am
7yrs+11,000 Posts
7yrs+11,000 Posts
maybe, i couldent sighn up till 12 at night for "budget reasons"
