It is currently Tue Sep 02, 2014 11:05 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3  Next
 Post subject: Video Card FRYS and shoots flames
PostPosted: Mon Aug 23, 2004 10:44 pm
6800 GT
6800 GT
Ok, system POSTs fine until I installed the PNY GeForce6800 GT today, secured it in the AGP slot, plugged a 12v into it, powered on the system and it decides to shoots flames.
AMD Athlon64 3000+
Antec TruePower 480w True Blue
Gigabyte K8NS Pro mobo
Gigabyte 3D Cooler Pro HSF
Corsair XMS Pro XL pc-3200 ram (2x 512mb)
Soundblaster Audigy2 ZS Gamer
Samsung 160gb 8mb buffer SATA HD
(FRIED)PNY Verto GeForce 6800 GT
1x Thermaltake Thunderblade 120mm rear fan
2x Logisys Alien 80mm fans
2x Vastech 80mm fans for intake
Memorex 16x DVD Rom
NEC floppy
Vantec Nexus Fan Controller hooked to the 4 80mm fans
http://www.dfwls1.com/hosting/albums/userpics/10896/1.JPG
Opinions?
PostPosted: Mon Aug 23, 2004 10:47 pm
6800 GT
6800 GT
http://www.dfwls1.com/hosting/albums/userpics/10896/2.JPG
PostPosted: Mon Aug 23, 2004 10:48 pm
6800 GT
6800 GT
Bottom of the card
http://www.dfwls1.com/hosting/albums/userpics/10896/3.JPG
PostPosted: Mon Aug 23, 2004 10:50 pm
ouch! that sux. does the rest of ur system still work?
PostPosted: Mon Aug 23, 2004 10:54 pm
6800 GT
6800 GT
Dont wanna try it, lol, kinda afraid now. The rest of the system looks undamaged but who knows. But like I said, yesterday, it ran fine posted and all. We had it running for a good 2 or 3 minutes w/o a problem, today hooked in the video card, plugged in the molex and powered up the system. Then foosh, flames start shooting out of the Video Card. WTF?? :evil:
PostPosted: Tue Aug 24, 2004 12:00 am
6800 GT
6800 GT
Ok, the system posts without the card installed so everything else is undamaged to my knowledge. wtf
PostPosted: Tue Aug 24, 2004 1:36 am
well, if u hooked the card up correctly, then it's apparently a manufacturing mistake, send it back. ive never had anything do that to me before tho, and id be glad the rest of ur system still works.
PostPosted: Tue Aug 24, 2004 5:40 am
Contributing Writer
Contributing Writer
1) Resize your pictures
2) Contact the dog pound. A failing video card is one thing, but catching on fire in your system is quite another.
PostPosted: Tue Aug 24, 2004 6:07 am
and send the pics to Kyle at hardocp, he loves stuff like that, I'm pretty certain they'll show up on the front page.
PostPosted: Tue Aug 24, 2004 7:17 am
turn on the macro mode on your camera, or use the autofocus properly.
PostPosted: Tue Aug 24, 2004 9:08 am
6800 GT
6800 GT
It was 2am and the best lighting I had was the kitchen light. :roll:
Thanks to all the people with actual helpful advice.
PostPosted: Tue Aug 24, 2004 9:52 am
it has nothing to do with lighting. macro mode helps you with close shots. you don't see the blurriness?
do you always take advices as insults?
 Post subject: Re: Video Card FRYS and shoots flames
PostPosted: Tue Aug 24, 2004 10:39 am
Emwun Garand wrote:
Opinions?
Shoulda gone ATi :P Probably just a bad card if it fried on the first try like that. Call up their customer service department and wail on 'em.
PostPosted: Tue Aug 24, 2004 11:00 am
7yrs+11,000 Posts
7yrs+11,000 Posts
its just not a high pixil camera.
PostPosted: Tue Aug 24, 2004 11:02 am
i definitely think you should call pny. it is an obvious manufacturing defect if the first time the card has power applied to it it shoots out flames. if pny hassels you send an email to the watch dog at maxpc.
PostPosted: Tue Aug 24, 2004 11:13 am
Aloha, [H]ard|OCP did post a picture and that's how I found my way over...
I don't have a 6800GT and I can't find any good pictures showing that (or similar Nvidia reference-design boards) any closer than this:
FiringSquad
But the parts under that mini heatsink are part of the power regulation circuitry for the secondary molex connector, and what very likely happened is that your card had a defective part, which went short-circuit. The result would be that it instantly dumped many amps of current, superheated, and 'flashed.' The flames you saw spitting out were that part's casing vaporizing. Good thing you were there to witness the failure and pull the plug before damage occurred elsewhere in the system!
I wouldn't be worried about getting another card of the same type/brand; a failure like this is almost certainly a rare defective component rather than a faulty design. But you are definitely entitled to a free replacement.
PostPosted: Tue Aug 24, 2004 11:30 am
Contributing Writer
Contributing Writer
Emwun Garand wrote:
Why dont you ________? It was 2am and the best lighting I had was the kitchen light. :roll:
I don't think anyone was trying to insult you Emwun. You're getting some good exposure to those pics from this forum and the link at [H]ardOCP, so they're just trying to help you get pics that are a bit more clear :)
As for the size, to keep from breaking the tables they need to have a width at or below 640. It keeps the threads (and the forum as a whole) from becoming an eyesore with unnecessary side-scrolling. I imagine you're perfectly capable, but if you need help due to lack of an appropriate program or any other reason, we'll gladly help you out 8)
Thx
PostPosted: Tue Aug 24, 2004 12:40 pm
it(stateing the obvios here) looks like the volt regs overloaded. definatly send it back. i had a similer thing(5.5 volt line somehow fried my first 9800, but it happened at the molex, and all the plastic around it swelled... i hate the smell of burning plastic. ill dig up some pics of the card if you want
(yay first post!)
PostPosted: Tue Aug 24, 2004 1:31 pm
Astro lube 2 the MAX!
Ouch that sucks. I heard PNY has a terrible warranty plan. So I hope you can get a new one.
PostPosted: Tue Aug 24, 2004 2:08 pm
LOL SO COMFORTING. Might as well kick him in the nuts ;)
Wazer
