It is currently Thu Apr 17, 2014 3:19 pm
 Post subject: Jolicloud Fail
PostPosted: Mon Jul 25, 2011 4:37 am
So I just finished reading all the pros listed in this month's issue and I decided to dual boot Windows 7 and Jolicloud. Problem is every time I try this, I get an error when attempting to boot: no jolildr, missing MBR-helper. This appears to be a somewhat common issue with people. Though what I've concluded is the file becomes corrupt over time as per what I've read with other people's experiences. Of course the stupid thing never worked for me at all. So yeah, so far, this is a pretty fail OS...
 Post subject: Re: Jolicloud Fail
PostPosted: Mon Jul 25, 2011 2:49 pm
You've concluded that the file became corrupt over time even though you never got it working in the first place?
PostPosted: Mon Jul 25, 2011 11:59 pm
Or, you could have read what I actually said: "as per other people's experiences..." Either way it was just conjecture. That has nothing to do with the main point at hand...
PostPosted: Tue Jul 26, 2011 5:55 am
Wow...imagine if I went to the doctor's office and proclaimed that I had some ailment just simply because a few other people had it.
This really must be the worlds shortest half-life of file corruption...
or you just have an ax to grind with Jolicloud or even an alternate OS in general.
PostPosted: Tue Jul 26, 2011 10:12 am
pathscience wrote:
Which is ... what?
PostPosted: Wed Nov 16, 2011 10:28 am
Probably a problem with the install. I never had a problem with it (I'm posting using it now), but it's on a dedicated partition.
