It is currently Wed Jul 23, 2014 2:34 pm
 Post subject: Optional Windows Update allows deleting outdated Updates
PostPosted: Mon Oct 14, 2013 3:49 am
One of the optional updates this past Tuesday was KB2852386, which adds the ability to delete obsolete updates, etc. using the Windows Cleanup tool in Windows 7. I freed up 16Gb just now! I suspect ccleaner will add the ability pretty soon...if I haven't missed it in the past. [h/t to DadCooks' for this how to link.] Of course the penalty will be that you may be unable to roll back to a superseded update and have to manually install it instead if needed---how often have you had to do that.
