It is currently Sat Apr 19, 2014 12:44 am
 Post subject: Installation HELP PLEASE
PostPosted: Sun Sep 15, 2013 10:03 am
My windows installation key was already used (by me) and i want to reinstall windows 7 onto my laptop and i can't read my code because my code got smudged what do i do??? :cry:
 Post subject: Re: Installation HELP PLEASE
PostPosted: Mon Sep 16, 2013 10:55 pm
As long as that Windows is being installed on one computer, it doesn't matter if it's used or not. Just use the phone-activation service. Also if this is a laptop from an OEM, you should just be able to do a factory reset without having to activate anything.
PostPosted: Mon Sep 30, 2013 4:47 am
Use the Jellybean Keyfinder to pull the key out of your running windows install.
http://www.magicaljellybean.com/keyfinder/
Scroll to bottom of page and take free version, choose custom install and uncheck the three checks. :mrgreen:
Remember, you can only have that key running one machine and not two!
