It is currently Fri Apr 18, 2014 6:01 pm
 Post subject: What is this?...Windows Update: Graphics Adapter WDDM update
PostPosted: Wed Mar 27, 2013 9:46 pm
I already have the latest NVIDIA driver installed on my Windows 7 x64 for my GeForce GTX 660 Ti. But I got this item in my Windows Update list. Is this something different from NVIDIA drivers--and therefore I should install it? Or should I hide this update and ignore it?
Quote:
nVidia - Graphics Adapter WDDM1.1, Graphics Adapter WDDM1.2, Other hardware - NVIDIA GeForce GTX 660 Ti
Download size: 227.8 MB
You may need to restart your computer for this update to take effect.
Update type: Optional
nVidia Graphics Adapter WDDM1.1, Graphics Adapter WDDM1.2, Other hardware software update released in January, 2013
More information:
http://sysdev.microsoft.com/support/default.aspx
Help and Support:
http://support.microsoft.com/select/?target=hub
 Post subject: Re: What is this?...Windows Update: Graphics Adapter WDDM up
PostPosted: Thu Mar 28, 2013 6:52 am
Just ignore it. In fact, ignore all driver updates from Windows. Though you may want to check if you do have the latest from the manufacturer if it flags you "need" one.
