It is currently Thu Jul 31, 2014 5:12 am
 Post subject: Windows 8 and Hyper-V
PostPosted: Tue Feb 05, 2013 2:04 pm
Do any of you have a link to a good howto on setting up Hyper-V on Windows 8 Pro machines? I have a Windows 98 .vmc from Virtual PC and it's got Starship Titanic (old Douglas Adams game), which I don't want to live without.
I'm running Windows 8 Pro on this setup:
Core i5 3570K
8.00 GB Dual-Channel DDR3
Gigabyte Z77-DS3H
GeForce GTX 550 Ti (EVGA)
Any helpful hints appreciated. There was a utility for turning .vmc files into the format Hyper-V wants, but it appears to be from 2011 and it didn't work with Windows 8 Pro GA.
 Post subject: Re: Windows 8 and Hyper-V
PostPosted: Tue Feb 05, 2013 3:25 pm
WELCOME! Welcome to the MaxPC FORUMS. Please make sure you don't just play a voyeur - be sure to actively contribute, advise and help someone else out. This place is only as good as it's participants - it's all about quality and timely I/O.
To enable is easy peasy...
1. On the Control Panel, click Programs, and then click Programs and Features.
2. Click Turn Windows features on or off.
3. Click Hyper-V, click OK, and then click Close.
PostPosted: Wed Feb 06, 2013 5:05 am
So far, I was able to follow the above advice, and find TenSeldamUtility2009_03.exe, which, when installed, can convert the Virtual PC 2005 and 2007 .vmc to a virtual machine that works with Hyper-V. But the virtual machine fails on boot, so I'm digging out the old Windows 98SE .iso, and trying to create the VM that way.
Thanks for your help!
