It is currently Thu Apr 17, 2014 2:39 pm
 Post subject: M11x R3 MSATA?
PostPosted: Sat Feb 16, 2013 11:14 pm
I replaced the thermal on my M11x R3 and when putting the WiFi card in I noticed this, it appears to be a port of some sort. It has seems to have plenty of space in front of it for a card of some sort, could it be for a MSATA drive? If it is that'd be great as I could have a 750GB Hybrid HDD for DATA and a 128GB MSATA SSD for my OS! BTW how do these temps sound for a idling M11x R3 i5? CPU 50C, GPU 40C. Thanks! :)
I CAN'T UPLOAD A PHOTO!!! THIS HAS HAPPEND ON EVERY COMPUTER OR DEVICE I HAVE USED!!! THE UPLOADER PROGRAM (or whatever you'd call it) MUST BE BROKEN BECAUSE NOTHING WORKS,DIFFERENT PC OR PHOTO FORMAT. THE PORT IS ABOVE THE WIFI CARD. I WILL UPLOAD A PHOTO IF I CAN GET ONE TO.
 Post subject: Re: M11x R3 MSATA?
PostPosted: Sat Feb 16, 2013 11:18 pm
Monkey Federation (Top 10)
I always had better luck uploading pictures to photobucket or a similar service then linking to it in my post.
PostPosted: Sat Feb 16, 2013 11:26 pm
It's most likely a mini PCI-Express slot, which won't do you any good.
And those temps are fairly normal.
PostPosted: Sun Feb 17, 2013 12:40 pm
If it is a mini PCI-E what can it do? Could I put my GTX 580 in it? LOL! :P
PostPosted: Tue Feb 26, 2013 4:58 pm
Seriously what use is a mini PCI-E?
PostPosted: Tue Feb 26, 2013 6:01 pm
Another wireless card.
PostPosted: Wed Feb 27, 2013 3:33 pm
Why would I need two? Also I only have hook ups for one.
PostPosted: Wed Feb 27, 2013 4:49 pm
You asked what you could use the other mini PCI Express slot for.
As far as I know, mini PCI-Express slots are only for WiFi cards.
PostPosted: Thu Feb 28, 2013 11:37 am
OK! Thanks!
