It is currently Thu Jul 24, 2014 3:09 am
 Post subject: XP and Vista Certification
PostPosted: Fri Dec 30, 2011 4:40 pm
Team Member Top 100
Team Member Top 100
If a person is certified in Vista (70-620), how hard or how much studying would be needed to past the XP 70-270 exam?
 Post subject: Re: XP and Vista Certification
PostPosted: Sun Jan 01, 2012 9:17 am
Probably not much studying at all if you still remember everything from the Vista exam, the objectives don't seem all that different.
XP Objectives
Vista Objectives
And the For Dummies site is giving their ebook away right here if you want something to skim over.
PostPosted: Mon Apr 23, 2012 8:37 am
Even though you may know Vista you need to understand what is different in XP. XP and Vista are not the same OS, and some principals that applied in XP no longer exist in Vista and 7, however I can't see the test being that hard. I recommend ditching XP and aiming for Win 7 because XP will no longer have support in 2 years from now, so most companies wont be using it anymore.
