It is currently Fri Aug 22, 2014 9:18 am
 Post subject: Java
PostPosted: Sat Jul 16, 2011 7:03 pm
Hey All!
I'm taking a Java programming class this fall semester. I know nothing about Java.
Does anyone know of a good site for the absolute beginner to look over? Or even the best book to get? I would like to have at least a little knowledge about Java before the class starts.
Thanks!
Fatman
 Post subject: Re: Java
PostPosted: Sun Jul 17, 2011 12:27 pm
If you check the Programmer's folder, you'll find that we have sticky threads that answer your question with links to popular resources for new coders.
PostPosted: Sat Jul 30, 2011 8:46 pm
Hey bud, I took Java this past year in the same position you're currently in. I'm going to try to stay active on the forums amidst the football, drumline practice, swen work, etc... I used Java for dummies and did some prereading. It gave me a huge advantage in the class!!! If you come up with any questions, I can try my best to help. Feel free to PM me or something with questions.
-breezy
PostPosted: Sun Jul 31, 2011 8:25 am
Thanks breezy! I'll keep that in mind!
PostPosted: Tue Jan 03, 2012 10:01 pm
hey... :roll:
Javascript is a scripting language developed by Sun Microsystems. Javascript has been used to customize web pages. You can customize your web page to check out who's browsing (by reading the viewer's cookies) figure out where else they've been or where they're located and start putting advertisements for your local area or for other interests that you have shown by your past viewing.....
