It is currently Wed Aug 27, 2014 3:41 am
 Post subject: Rubberized mouse grip material
PostPosted: Fri Oct 26, 2012 9:06 pm
I have a Razer Abyssus mouse that I enjoy using. The only problem with it is the grip material- the top has a nice, soft rubberized surface, but the sides where you put your thumb and pinky are glossy hard plastic. This surface doesn't feel very good and gets caked up with crud every two weeks or so. I'd like to mod my mouse to add a more comfortable surface to the sides.
My question is, does anyone know where I can find a grippy surface? Something that already has an adhesive side would be ideal. Thanks for the help.
 Post subject: Re: Rubberized mouse grip material
PostPosted: Sat Oct 27, 2012 6:29 am
You'll probably want adhesive backed Neoprene Rubber 1/16(1.58mm) or 1/32(0.79mm) thick, in the range of 30A - 40A durometer(hardness), 30A is about the same as a rubber band, car tires are usually around 60A-70A
1/32nd inch 30A
1/32nd inch 40A
1/16th inch 30A
1/16th inch 40A
