It is currently Wed Jul 23, 2014 12:26 pm
 Post subject: Planning a build, need help
PostPosted: Wed Oct 03, 2012 9:44 am
I have always wanted to do something different with my cables inside a case. I don't want to go real extravegant, just different. One idea was sleaving my cable and running it inside the tubing for watercooling. Another idea was sleeving it and that is all. But, the part that is bothering me, which I can't think of what to do or what to use, is I want to put the molex connectors and other connectors into something. Molex connectors are too "plane" to me. I would like to do something to make them look more steampunk or industrial or something. Any ideas?
 Post subject: Re: Planning a build, need help
PostPosted: Wed Oct 03, 2012 11:44 am
Metallic spray painted PVC pipes, or something. Or you can get these http://www.amazon.com/Prime-Wire-Cable- ... B000ZIKTJY and spray paint them.
And then make a custom housing for the rear on the drives so it looks seamless.
