It is currently Tue Sep 02, 2014 10:37 am
 Post subject: Cleaning my PC
PostPosted: Thu Jul 11, 2013 11:13 pm
HI all,
So I wanted to format my computer and start afresh with Windows 7. Is there a best way to do this? I usually just format using the Windows disk but if there is a better program I'd prefer that.
And what is the best order to reinstall drivers and what not?
Thanks,
8)
 Post subject: Re: Cleaning my PC
PostPosted: Fri Jul 12, 2013 12:12 am
Unless you need to be absolutely certain that the data is erased, the formater in Windows install is fine. Formatting doesn't actually erase anything, it just writes a new partition table. Otherwise use Parted Magic to do a secure erase.
As for what drivers to install... The motherboard chipset and related I find generally to be the first thing to install. After that, you can install everything else in any order that you want.
PostPosted: Wed Jul 31, 2013 7:50 am
I find the best way to clean my computer and make sure it is totally clean is to use Scrubbing Bubbles. You can get this at any local super market
