It is currently Mon Jul 28, 2014 3:37 pm
 Post subject: Dual monitor screen brightness
PostPosted: Sun Jun 16, 2013 3:20 pm
I have a problem on my main rig. I run 2 28 inch monitors, and the right one (secondary display) is substantially dimmer than the left monitor (main display). Now obviously I could just adjust the brightness on the monitor, but here's the rub. I dual boot this rig between XP home 32bit and 7 Pro 64bit. The issue is only in the Win 7 install. In the XP install both displays are perfect. Any ideas? FWIW one monitor is connected using DVI, and tho other using HDMI, both connected to the top video card in the system.
3770K CPU
ASUS P8P67 Deluxe MB
16GB Corsair RAM
(2) EVGA GTX560ti video cards
Sb Audigy ZS sound card
 Post subject: Re: Dual monitor screen brightness
PostPosted: Wed Jun 19, 2013 12:42 pm
In the control panel, under Color Management > Devices there appears to be your option to setup profiles for each monitor, have you tried to use it?
