It is currently Tue Jul 29, 2014 9:58 am
 Post subject: Blue Screen Error!!
PostPosted: Fri May 31, 2013 8:27 pm
I went on my desktop today to find it in startup repair. It was stuck on the loading screen for a long time, so I restarted it and got the blue screen. I'm assuming that the reason it was in startup repair is because it got the blue screen while I was away, then restarted itself and went into startup repair by default. I can't get onto the desktop even when I go into safe mode, so I can't access any of the files that I want to save. On the blue screen, it says BAD_POOL_HEADER at the top and at the bottom it says:
*** STOP: 0x00000019 (0x0000000000000003, 0xFFFFFA8003C462E0, 0xFFFFFA8003C462E0, 0x0000000000000000)
Other than that it is all the usual stuff you would see on a blue screen error.
Is there any way to completely fix this? Or is there at least some way I can access my files so I can move them onto an external hard drive to save them?
Thanks
 Post subject: Re: Blue Screen Error!!
PostPosted: Fri May 31, 2013 8:44 pm
What version of Windows are you using? Do you have the Windows installation disk? If so, does it include the most recent Service Pack?
PostPosted: Fri May 31, 2013 10:22 pm
Check out these two articles:
Bug Check 0x19
http://msdn.microsoft.com/en-us/library/windows/hardware/ff557389%28v=vs.85%29.aspx
Resolving stop (blue screen) errors
http://windows.microsoft.com/en-US/windows7/Resolving-stop-blue-screen-errors-in-Windows-7
Hope this helps
PostPosted: Sat Jun 01, 2013 1:15 am
Just poke some of those numbers into Google. What comes up will point you in the right direction. Google will help answer just about any computer question.
PostPosted: Sat Jun 01, 2013 4:50 am
I'm using windows 7, and I still have the installation disk
PostPosted: Sat Jun 01, 2013 10:24 am
Try running a repair installation with the Windows 7 installation DVD. Here is a link that will tell you how: http://www.sevenforums.com/tutorials/34 ... stall.html. Good luck!
PostPosted: Sat Jun 01, 2013 8:06 pm
Run the free diagnostic app from the hard drive maker on the boot drive. Be prepared to write down any error code. If it offers to fix anything I would consider a sector-by-sector copy if you have another PC and a large enough HDD on it before allowing a fix attempt. If it does "fix" the drive I would back it up immediately and replace the drive.
If the drive passes, I would probably boot up and run memtest86 because it is easy to do though in this case I don't think it is the problem---I suspect failing sectors.
PostPosted: Sun Jun 02, 2013 4:11 am
Do as pcstudent says and use the win 7 dvd to "Repair" windows. It sounds like you installed a driver that windows didn't like and crashed the system. You could also choose last best known configuration in the safe menu and/or use the restore option to go to a day when it worked properly.
