It is currently Fri Aug 01, 2014 8:44 am
 Post subject: Is WMSysPr9.prx a virus?
PostPosted: Thu Dec 10, 2009 2:36 pm
SuperAnti-Spyware froze while scanning WMSysPr9.prx. I read somewhere that it was a trojan. Is it?
PostPosted: Thu Dec 10, 2009 2:44 pm
Malware specialist
Malware specialist
Can you do a search on your computer and tell me the location of that file?
It could be a Windows Media Player file or a Trojan. All depends on the location.
its in the windows folder
PostPosted: Thu Dec 10, 2009 2:52 pm
Malware specialist
Malware specialist
Can you try downloading another scanner (such as MalwareBytes' Anti-Malware) and running a Complete System Scan with that?
It does look like it might be infected. But could still be an oddly placed file.
PostPosted: Thu Dec 10, 2009 2:54 pm
if it helps, i already ran norton and malwarebytes.
I made a backup in gmail and tried to delete it, but windows wouldn't let me. is that normal?
PostPosted: Thu Dec 10, 2009 3:06 pm
Malware specialist
Malware specialist
Yeah, Windows doesn't like people to delete things out of the C:\Windows folder.
To be honest, if you aren't having any problems, I wouldn't worry about it. If it went through MBAM and Norton just fine, it's probably just a file that SAS has problems scanning.
