It is currently Tue Aug 19, 2014 11:17 pm
 Post subject: First time building..help needed
PostPosted: Sun Jun 30, 2013 8:35 am
and dont know what to get. have around $500-$700 budget
was looking for something like this
GeForce GTX 650 Ti BOOST 2GB 192-bit GDDR5 PCI Express 3.0
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Crucial Ballistix Sport 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory (comes with motherboard)
AMD FX-6350 Vishera 3.9GHz Socket AM3+ 125W Six-Core Desktop Processor FD6350FRHKBOX
and the rest.. can anyone please make suggestions and help to build something similar to this ? Thank you
 Post subject: Re: First time building..help needed
PostPosted: Wed Jul 03, 2013 10:03 pm
Check out this website to get an idea of what you can afford within your budget. And if you plan on using Windows as your OS, that will cost another $100.
http://images1.wikia.nocookie.net/__cb20121225224246/4changboard/images/7/76/Falconguide-dec2012.png
Hope this helps.
PostPosted: Sat Jul 06, 2013 12:54 pm
If this is gonna be primarily a gaming rig, six cores is a little over zealous. Go for the quad instead, save yourself a couple bucks there. Also, you need to factor in the cost of the operating system, case, psu, optical drive and so forth. All things considering, 700 bucks for a gaming rig is a tall order. Look for sales, maybe a spare case from a friend.
Even then, you might wanna consider AMDs APUs, as they have a processor and graphics card in one, for the price of that particular proc.
