It is currently Sat Apr 19, 2014 2:32 pm
 Post subject: Looking to upgrade PC, need some adivce!!!
PostPosted: Sat Jun 29, 2013 2:35 pm
My PC I have right now is decent but I want to improve it. My video card is AMD Radeon HD 6900 Series. Processor is Intel Core i7 CPU 960 @ 3.20 GHz, 3201 Mhz 4 Cores 8 Logical Processors. 12 GB Ram. Sabertooth X58 Motherboard. 750w Power supply. Antec 1200case. I'm want to get a better graphic card to run along side my 6900, wondering which would card would be the best. I was thinking about getting the Nividia GTX 780 but I don't to spend 650$ if I could get something cheaper. I just want to run my games in ultra with at least 60 fps no lower. more would be better. My monitor is only a HP 1920x1080 60hz looking to upgrade this to if you guys know any great monitors like 120hz I was looking at. THANK YOU !!
 Post subject: Re: Looking to upgrade PC, need some adivce!!!
PostPosted: Wed Jul 03, 2013 10:39 pm
Generally speaking, nVidia and AMD don't work well together, so a 780 and a 6900 series are not a good mix. If your motherboard supports Crossfire you can find the same 6900 series GPU and run them in tandem (of course, there is the frame-rating issue, but I believe AMD will have this resolved soon).
If that doesn't sound good, try nVidia's 760, or AMD's 7970 for a single card solution.
Hope this helps.
PostPosted: Tue Jul 16, 2013 5:30 am
Looking for upgrade path for:
Intel I5 2500k
Asus motherboard p8p67 pro
gpu 560ti X2
with 16 gb ram
my question should can I upgrade and if so to what or should i can it and go to haswell cpu?
