It is currently Thu Aug 28, 2014 5:32 pm
 Post subject: DFI lanparty dk790fx problem!
PostPosted: Thu Jun 27, 2013 2:31 pm
So i have the lanparty dk790fx MB In a case that i got from my sister who got it from her friends dad, he said all it needed was a HD, it ended up i got a new graphics card PSU and 750gb hard drive. I just installed the new PSU and the MB light doesn't turn on when i flip the switch, and the Computer does not boot at all. I can give more details as needed. I can't get this to turn on and it's so... FRUSTRATING. Thanks in advance! Shady
 Post subject: Re: DFI lanparty dk790fx problem!
PostPosted: Thu Jun 27, 2013 5:36 pm
a few questions, are the secondary power plugs plugged in, one on the motherboard and should be one in the video card, did you format the harddrive, do you have the installation disk for the motherboard?
PostPosted: Thu Jun 27, 2013 5:38 pm
Hey, I got it fixed, i was using an 8 pin and no spacers for the motherboard to case, i put the spacers in and then used a 4-pin and it's running now! Thanks for trying to help! If someone could close the topic, If this forum has that. That would be great! Thanks! :D
