It is currently Tue Jul 22, 2014 7:48 am
 Post subject: Time for an upgrade or fine for 2013 and higher?
PostPosted: Wed Jun 26, 2013 3:42 pm
Hey guys. So my specs are:
GTX 560 TI
I7 2600
16 gb ram
2 TB HDD
128 gb SSD
Resolution: 1920 x 1080
The GPU and CPU are both slightly overclocked, but im just wondering if I'm fine to play the games coming out soon, "next gen". Ive been able to max out every game so far with no problems. Its held me well, but I'm just wondering about the near and far future. Thanks!
 Post subject: Re: Time for an upgrade or fine for 2013 and higher?
PostPosted: Thu Jun 27, 2013 11:51 am
Your 560Ti should be fine if you're okay with playing on high settings at 1920x1080, but if you want to play on Ultra you might want to upgrade to a GTX 760. Here's a GTX 760 from EVGA http://www.newegg.com/Product/Product.aspx?Item=N82E16814130933. Your CPU is fine I wouldn't upgrade it if I were you as gaming is more GPU intensive than CPU intensive.
Users browsing this forum: crazycanukk, LatiosXT and 7 guests
