It is currently Fri Aug 29, 2014 3:31 pm
 Post subject: Help me with 1st build please
PostPosted: Thu Jun 20, 2013 5:17 pm
I am building a new comp from scratch here. No recycled parts. I already have a monitor/mouse/keyboard so I am talking strictly a tower here.
I am building this to play league of legends on the highest settings possible with a $500 budget. NO MORE!
I have spent about 2 hours looking so far and here is what I have come up with...
RAM: 8GB ($--)
HD: --($--)
PSU: SeaSonic M12II 620 (89$)
GPU: SAPPHIRE 100314-5L Radeon HD 6870 ($129)
CPU: AMD FX-8120 ($159)
MOBO: ASRock 980DE3/U3S3 ($69)
OS: W7 OR W8 ($FREE)
Might have to adjust a bit, but this is just rough. Let me know if I am on the right track (as in is everything compatible?).
Thanks!
 Post subject: Re: Help me with 1st build please
PostPosted: Thu Jun 20, 2013 7:02 pm
You have a pretty good start - at $500 you have to be a real stickler with each dollar. So far, using the prices you listed (which doesn't include shipping) you're at $446 - that leaves $54 for an HDD and RAM which isn't realistic.
Here are a few things I noticed:
  • Seasonic PSU are great and they're expensive. This Corsair Builders Series is ample for your build and is $40 cheaper and has a $20 rebate.
  • The 6870 is a generation older - try the 7790. It's about the same price and comes with 3 games. If you don't want the games you could sell them to help offset the cost.
  • The CPU is a good choice and the mobo looks pretty good too. If you need to cut costs, you can drop down to the FX 6300 which is $40 less.
  • RAM is pretty standard so I would pick one that's cheap and has a lot of positive reviews on newegg. Oh, and you need 1333 (also called 10600). It's compatible with your mobo and doesn't require OCing.
  • HDDs are tricky in that smaller sizes often don't save much money (if any). Be on the look out for a 1TB HDD on sale for $60 - it happens frequently and that's the going rate for a 500GB.
  • Not including the CPU savings, you have $94 (54+40 from the PSU). 8GB of RAM plus an HDD is going to run at least $120 ($60 each). As I see it, you have a few options:
    1. Drop to a lesser GPU (which I don't recommend)
    2. Move to the cheaper CPU (a good option, but I think there's a better one)
    3. Go with 4GB of RAM (I see it as the best option). You can pick up another 4GB for $30 down the road and is the easiest thing to install in a computer.
Hope this helps.
PostPosted: Mon Jun 24, 2013 5:58 pm
New question. I am looking at just about every CPU out there right now and I see two numbers when looking...
1) The # of core's
2) The # of GHz's
So, for a gaming setup for League of Legends do I aim for more GHz's, or more core's? It seems like you either get alot of GHz and less core's or vis versa (at least for my price range).
PostPosted: Mon Jun 24, 2013 6:16 pm
Neither, because more of either doesn't mean a better preforming processor.
PostPosted: Mon Jun 24, 2013 7:18 pm
Update
So here is what I have come up with after much research. Please let me know if these parts are not compatible.
RAM: Crucial Ballistix Sport 8GB (2 x 4GB) ($Free)
HD: Western Digital WD Blue WD10EZEX 1TB ($69)
PSU: Diablotek PDA Series PDA-650BW (61$)
GPU: SAPPHIRE 100358OCL Radeon HD 7770 ($100)
CPU: AMD FX-4350 Vishera 4.2GHz ($119)
MOBO: BIOSTAR TA970 ($79)
OS: W7 ($100)
Total: $535
