It is currently Sat Aug 30, 2014 12:49 am
 Post subject: My modem is SLOOOOWWWW
PostPosted: Thu Apr 04, 2013 7:29 am
Team Member Top 250
Team Member Top 250
My modem has been slow lately and I'm not sure why. I did some investigative research and was introduced to my modem's web interface. I have no idea what the numbers mean. Can anyone help? If you see a problem could you please recommend a course of action? I know it's hard to read but it won't let me upload my screenshot.
Downstream Bonding Channel Value
Channel ID 111 109 110 112
Frequency 705000000 Hz 693000000 Hz 699000000 Hz 711000000 Hz
Signal to Noise Ratio 38 dB 38 dB 38 dB 38 dB
Downstream Modulation QAM256 QAM256 QAM256 QAM256
Power Level
The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
6 dBmV 7 dBmV 7 dBmV 5 dBmV
Upstream Bonding Channel Value
Channel ID 1 2
Frequency 30000000 Hz 36500000 Hz
Ranging Service ID 8033 8033
Symbol Rate 5.120 Msym/sec 5.120 Msym/sec
Power Level 40 dBmV 41 dBmV
Upstream Modulation [3] QPSK [3] 64QAM
[3] QPSK [3] 64QAM
Ranging Status Success Success
Signal Stats (Codewords) Bonding Channel Value
Total Unerrored Codewords 97874848302 97875136002 97875138493 97874811863
Total Correctable Codewords 51132 11942 10938 62453
Total Uncorrectable Codewords 321573 70913 69500 346986
 Post subject: Re: My modem is SLOOOOWWWW
PostPosted: Thu Apr 04, 2013 7:50 am
It would be nice to to know what modem this is.
PostPosted: Thu Apr 04, 2013 7:58 am
Team Member Top 250
Team Member Top 250
Oops lol, been a while since I posted anything on these forums lol. I have the Motorola SB6120. I got it very shortly after it came out, however long ago that was...
PostPosted: Thu Apr 04, 2013 8:32 am
Actually I should've said this first:
  • We could take those values and make nothing of them. I don't know what a baseline "good" value is for this part, and I wouldn't think anyone else here would. This is something you take to Motorola.
  • Did you try resetting the modem or calling your ISP first?
PostPosted: Thu Apr 04, 2013 8:43 am
Team Member Top 250
Team Member Top 250
I called Comcast and their response was "everything is good on our end". So, by that, I'm inclined to believe there's something wrong with my modem. I found online that a value over 100k for the "uncorrectable codewords" is a sign that the modem is dying. But as you can see I have more than 2 channels. So I was generally asking if it should be more or less of a concern than would be otherwise, had it only had a single or dual channel. I'll send comcast a tech support email once I get home from work tonight, see if that helps any. I'll post again once I find out the cause/solution.
PostPosted: Thu Apr 04, 2013 10:32 pm
Monkey Federation (Top 10)
ALL ISP's first response is "It's not us". I think first level tech support for these company's are made to recite that line every morning when they punch in. I never speak to 1st level tech anymore. I always demand to talk to 3rd level or a manager. Most people with still try and help you but if you stand your ground and start sounding irritated they all give in eventually. Usually the real Tech person can answer any question I have in about 5 minuets. It normally takes me more time to get the right person on the phone then to get the answer.
For those that don't want to read that long wind: Summarized point Call ISP and be and ass till you get a real answer.
PostPosted: Fri Apr 05, 2013 7:12 am
Team Member Top 250
Team Member Top 250
Screw Comcast!!! I talked to them, they said they sent a code to reset my modem, but that I had to do the unplugging of cords. Took 3 resets to get it working again. In the mean time, since I wasn't on a phone that could reach (yes I was on an old corded landline), they hung up on me.
PostPosted: Fri May 03, 2013 8:24 am
Try changing the DNS addresses in your devices to Google DNS or Open DNS. Your problem could be crappy name resolution services of your ISP - VERY common.
