It is currently Sat Apr 19, 2014 11:27 pm
 Post subject: Check your Internet Speed through these top-5 online tools
PostPosted: Mon Sep 24, 2012 6:58 am
Speedtest is probably the most well known, but now you have four more tools to test your pipe.
1. Speed Test, http://www.speedtest.net
2. Bandwidth Place, http://www.bandwidthplace.com
3. Internet Frog, http://www.internetfrog.com
4. Test My Speed, http://www.testmyspeed.com
5. Broadband Speed Check, http://www.broadbandspeedchecker.co.uk
 Post subject: Re: Check your Internet Speed through these top-5 online too
PostPosted: Tue Sep 25, 2012 11:09 am
Prior to your list, I only knew of two:
http://www.dslreports.com (which I've used for about a decade)
http://www.speakeasy.net
Unfortunately, none of them help speed up the 4G on my iPad... wish I could get an external antenna or signal amp. But with the mobile speed test from speedtest.net, at least now I know that at one bar I get between 0.25Mbps & 1.5Mbps (no wonder it seems so damned slow all the time), with 2 bars I get around 4Mbps & with 3 bars I get around 7Mbps, just wish I saw 2 or 3 bars a lot more often :|
PostPosted: Wed Sep 26, 2012 5:09 am
Shocked! You have an iFad? At half the price, open ecosystem, and svelte utility I had you pegged as Nexus 7 owner. Geesh!
PostPosted: Wed Sep 26, 2012 6:46 am
Ya never know... As a musician I got it because of Garage Band! Besides I got it at penny auction for less than $75 :!: though I would rather have a MacBook Pro.
PostPosted: Fri Sep 28, 2012 12:54 pm
I could hock you mine, if you don't mind it being the first generation Intel Mac, 30% of the keys are missing (they still work), the DVD drive is busted, and it has a battery life of 0.
PostPosted: Thu Jun 27, 2013 12:04 pm
thanks for sharing all the links of testing internet speed i was searching this got this page but i got different results with them.
