It is currently Sat May 18, 2013 5:17 pm
 Post subject: downloads
PostPosted: Sat Jul 24, 2004 12:05 pm
Is there any way to download a movie (javascript) onto my computer instead of it just loading on my browser? Id like to share it wiht people and not have to load 4 megs on a dial-up everytime I want to watch it!
PostPosted: Sat Jul 24, 2004 12:37 pm
ive never heard of a javascript movie before ... have i missed something??
PostPosted: Sat Jul 24, 2004 1:55 pm
do you mean flash?
i also have never heard of java movies...
PostPosted: Sat Jul 24, 2004 2:54 pm
if it's flash, i can do it for u in a couple mins, just give me the link to the page that the flash is on and i will get it for u. if not, i have no clue.
PostPosted: Mon Jul 26, 2004 3:21 pm
If its flash, just take a peek at the source code, do a quick search for a link to a swf file and pop it into your address bar (if its relative, just edit the address line - remove the page name [abc.html] and add in the copied location). Wait for it to load and then save the file to your hard drive (or if you have a download manager, copy the address there and download it.
Respectfully,
Jacob
PostPosted: Tue Jul 27, 2004 7:27 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
If you mean flash, somtimes depending on the way you browser is configured as soon as you watch the movie it get downloaded in a way. Its just the means of finding the file. I dont know. Dont trust me. I just heard that someware.
PostPosted: Tue Jul 27, 2004 9:13 pm
whoops-yes its a flash movie- its from http://www.jibjab.com I'm just wonderin if u can download it somehow because its 4 megs and im on a dial up. takes a while to load each time on my 36 bps connection.
PostPosted: Tue Jul 27, 2004 9:14 pm
give me the name of the 1 that u want and i will give u a link to download it.
PostPosted: Thu Jul 29, 2004 2:31 pm
allrights-cool thx- Just go to http://www.jibjab.com The movie I want is the one on the homepage-with George Bush and John Kerry. How do you find a link to download it?
