It is currently Fri Jul 25, 2014 9:44 am
 Post subject: Tutorial: How to change Vista login background by elo231
PostPosted: Mon Mar 03, 2008 2:41 pm
Smithfield*
Smithfield*
In the March 08 issue of this lovely mag. On page 32, Paul (One4yu2c) mentioned about a program called Logon Studio which lets users choose a wide range of backgrounds. But for some of use we want our own so here how to do it manually with Vista.
Now before I go on here are a few things.
First I've checked online and there does not seem to be any tutorial on how to do it.
Second: I've learned this from PC Magazine (Vol.27 No.1/2 Special 25th Anniversary Edition) an article by David A Karp, but some of his steps did not work so I done it my way instead.
Anyway the credit goes to him for find out on how to do it.
Now without further yapping here goes:
1. Download XN resources
http://tinyurl.com/78jf2
2. Install XN resources
3. In the C:\ create 2 folders label: login backup and new login
4. Go to C:\windows\system32 and find the file "imageres.dll" (without the quotes)
5. Create a backup of that file by copying it to your c:\login backup folder.
6. Go back to c:\windows\system32 and right click on the file imageres.dll and then click on properties.
7. Now click on the following:
- Click the security tab
- click on Advanced
- click on the owner Tab
- click Edit (UAC appears continue)
- Select the "Administators" and click apply
A message will appear, click ok.
And keep on cliking OK until all the setting windows has been closed off.
8.Right click on imageres.dll again and click on properties.
click on the security tab, click edit (UAC=continue)
select the "administrators" and select allow full control.
Click Apply and OK.
- Close off everything until you reached your desktop
9. Get a pic you want for the login or create on on your own.
The picture you want to use will have to be the size of the current resolution your using.
e.g. If your resolution is 1600x1200 then the login picture will have to be 1600x1200.
If the picture you want is too large then resize it with a pictureing editing program of your choice.
10. When your done save it as a bmp format. (Tried it with jpg, but it does not work maybe I did it wrong)
11. Open up XN resources editor, click on View and select option.
Under "Choose which parser..." select "XN Resource Editor internal resource parser". Click Apply and OK.
12. Click File, open, navigate to C:\windows\system32 and open imageres.dll
13. Once opened you should see a list of folder to your left. Expand the "Image" folder and
inside you should see a list of addition folders with numbers on it. These individual folders are
the files to your login image. Change the one associated to your screen resolution. To do that you'll have
to look at each one until you find the right file.
This work has been done for you...
The first 4 digits are the folder names.
Folder and resolution may differ from monitor to monitor. What that means is your folder and
resolution may not be the same as the ones on the list. This was done on a standard 19" LCD.
5031: 1280x1024
5032: 1280x960
5033: 1024x768
5034: 1600x1200
5035: 1440x900
5036: 1920x1200
5037: 1280x768
5038: 1360x768
5039: 1024x1280
5040: 960x1280
5041: 900x1440
5042: 768x1280
5043: 768x1360
14. Open up MS paint, and open up the image you want to have as your login background.
15. Inside paint, click Edit and select all.
16. Click Edit and copy
17. Go back to XN Resource editor and go the folder for your resolution and click on the
"English (United States)" file under it.
18. Press Ctrl+V to paste.
19. Click on File save as and navigate to your "new login" folder inside your C:\
20. Save it as "imageres.dll" without the quotes.
21. When your done, restart and boot into safemode with command prompt
22. When login in command prompt should appear automatically. Go to your New login folder
and type in: copy imageres.dll c:\windows\system32
23. Press Enter, command prompt should tell you your over writing: Select A for all.
24. When your done type Exit and press Ctrl+Alt+Del and the right hand side a there should be
a red button, Select restart.
25. If have done it correctly than your new login screen should appear after the restart.
