It is currently Tue Sep 02, 2014 6:47 pm
 Post subject: Browser Hijacked? Fix it Here!
PostPosted: Mon Oct 11, 2004 5:45 pm
Chief Surgeon
Chief Surgeon
From InstigatorX:
Original Post
IF you are infected with CWS.Searchx or any spyware that makes your homepage about:blank or about:search (only this kind of spyware), follow below directions to clean it out.
Step #1-Download Stinger
http://download.nai.com/products/mcafee ... tinger.exe
Step #2-Go to start, run, type regedit
Navigate to HKEY_Local_Machine: SOFTWARE: Microsoft: Windows NT: Current Version.
Once there you will see a folder named Windows. Just rename it to Windows 2. Also, make sure there is no entry called APP_INIT.dll. IF there is, delete it.
Step #3-Go to http://www.majorgeeks.com/download506.html
Download Ad-Aware SE. Get the latest updates, scan your system using FULL SYSTEM SCAN feature.
Step #4-Download latest Cool Web Shredder prog at:
http://download.soft32.com/files/19014/CWShredder.exe
Reboot.
Step #5-stop looking at pron
Thanks, InstigatorX. :)
SC64
