It is currently Sun Jul 27, 2014 9:47 pm
 Post subject: Corsair H50 and Haswell compatible?
PostPosted: Sat May 04, 2013 9:45 am
Hi,
I am planning on purchasing a Corsair H50 CPU Water Cooler but I don't know if it will be compatible with the Haswell i5 I'm going to buy next month. Do you guys have any idea if it will be? Here's a link to the Cooler but I know most of you are familiar with it:
http://www.newegg.com/Product/Product.a ... 6835181010
 Post subject: Re: Corsair H50 and Haswell compatible?
PostPosted: Sat May 04, 2013 9:57 am
The mounting holes are the same as LGA1155, so yes, you can use an LGA1155 cooler in an LGA1150 board.
PostPosted: Sat May 04, 2013 10:36 am
Oh good. Thanks.
